Hey Joan;
Sorry, no clue re. viz render.
But your tutorials may be hiding because of a GID file in your Help folder. I found references to this behavior by entering "land tutorial" in a Search of the Autodesk Knowledge Base.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2899171&linkID=2475507
Before you start the process to get rid of this file, you should exit from all AutoCad sessions.
It's a hidden file so you will have to go to Windows Explorer and click the Tools pulldown; then Folder Options; then View tab:
Select the Show hidden files and folders option, then select the Civil 3D/Help folder to see if you can find one. Then delete it and start up C3D to see if the tutorials act normally once more.
Don Reichle
Hacker Engineering, Inc.
"King of Work-Arounds"
"albionpjl" wrote in message news:20856489.1099991632983.JavaMail.jive@jiveforum1.autodesk.com...
> I've been experimenting with the copy of viz render for civil 3D that came with civil 3D, but I am having some problems. For a start the tutorials (in viz) don't work; when I select tutorials from the help menu nothing happens.
> So I made a simple 3D drawing in civil 3D comprising two thickened closed polylines and a tube made by rulesurf between two closed polylines, and linked it to viz render.
> I found that the rulesurf tube doesn't render properly; only the back faces render, the front becomes invisible. I tried exploding it into 3dfaces with no improvement.
> I have a 3D castle reconstruction I want to try animating in viz render but most of the building surfaces are rulesurf and the same thing happens to them.
> Is there a way to make rulesurf surfaces render properly in viz render?
> And can anyone suggest what may be preventing the tutorials working and a way to fix it?
> thanks
> Joan
