I made a drawing with several grading and surfaces showing successive/cumulative land refills.
I want to do a layout for each phase (each filling) but I cannot find a way to freeze the *surface style* in a layout.
For example:
in a first layout, I want :
surface A is shown with contours 1m 5m while the surface B is hidden (style = _no display)
in a second layout, I want :
both surfaces shown with contours 1m 5m
I hope somebody can help,
Thanks and regards,
Pedro Torres,
Civil eng.
In your template, modify your Object Layers in drawing settings to have a suffix - this will then create the surfaces on different layers automatically (but doesn't dynamically delete the layer if you delete the surface)
neilyj (No connection with Autodesk other than using the products in the real world)
