Civil 3D Forum
freeze surface style in layouts, is it possible?
5 REPLIES 5
PedroTo
1181 Views, 5 Replies
I made a drawing with several grading and surfaces showing successive/cumulative land refills.
I want to do a layout for each phase (each filling) but I cannot find a way to freeze the *surface style* in a layout.
For example:
in a first layout, I want :
surface A is shown with contours 1m 5m while the surface B is hidden (style = _no display)
in a second layout, I want :
both surfaces shown with contours 1m 5m
I hope somebody can help,
Thanks and regards,
Pedro Torres,
Civil eng.
5 REPLIES 5
Jeff_M
in reply to: PedroTo
Put the Surfaces on different layers.....default is usually C-TOPO, so leave on on that layer, make another for the other one.
mathewkol
Set them all to the same style and place each surface on their own unique layers which you freeze/thaw as required for the layout.
You can't "freeze" a style.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
PedroTo
Many thanks for the trick.
Pedro T.
neilyj666
In your template, modify your Object Layers in drawing settings to have a suffix - this will then create the surfaces on different layers automatically (but doesn't dynamically delete the layer if you delete the surface)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
PedroTo
thanks, the suffix tip is perfect.
Rail Community
