Show only
Search instead for
When I label a line with "slope over distance" the arrow points downhill. When I label a line with "slope only" the arrow points up hill. If I use grade labels the arrow points uphill in either case. I need the arrows pointing in the same direction. Both of the slope labels on the same line point to different directions. I know you can reverse the label, but how would I know which label to reverse without gripping the line an viewing its properties. I would think that the purpose of labeling the slope of a line would to be able to immediately tell, by looking at the label, the slope of the line and which direction is up hill.
In the 2008 NCS extended template, there is a label style called Slope Over
Distance. In that label style, the rotation of the arrow block is set by
using an expression with an IF statement. Take a look, I think that will
solve your problem.
I'm not exaclty sure what you are talking about but I compared the slope only style to the slope over distance and noticed that the slope only arrow rotation was 0d and the slope over distance arrow rotation was blank. So I set the rotation to 0d and it works. Just one more way to confuse someone I guess. Seems like they would match since the template is "out of the box". Thanks
I see, so your saying that the arrow points in the direction that the line was drawn and has nothing to do with the elevation. Unless there is away to place positive or negative signs to denote elevation the arrows will inevitalby cause some misinterpretations.
In that style, edit the arrow and click in the "rotation angle" field. You
should see a drop down list with "Grade Check" as an option. If you select
that, it will use the grade check expression to set the arrow direction to
point down hill.
Cheers,
Peter Funk
Civil 3D Product Manager
