I am trying to calculate the cut/fills for an existing road that is going to be reconstructed. The depth under the new curb is different than the depth under the pavement. So, I created two existing surface by dropping the elevations and I created a datum surface from the corridor. Problem is that I am getting an error that materials define a common area, but when I check my polygon booundries they and corridor, I don't see anything overlapping. I have tried deleting and redoing the polygon boundry, but that hasn't helped. I even offset the boundries by .01 so they aren't on top of each other, but that isn't working either. I attached the drawing and zoomed into the cross section that I am getting the error at.
Any suggestions would be greatly appreciated!
Solved by tcorey. Go to Solution.
When are you getting that error?
Delete the sample line at 2875.011 and create one at 2875.00
Thank you! That worked. There were a couple of other stations (29+35, 32+61, 35+50) that were not calculating the cut from EOP to EOP, so I also moved those over and they worked too. Is this a glitch, or am I doing something wrong?
On another note, I was watching one of your you tube tutorial on how to extract boundries from the the corridor feature lines. I tried doing this with the same file. I was able to get the EOP polygon, but when I tried to due the BOC have the lines disappeared when I use the join command in PEDIT. Do you have any ideas on why it would be doing that?
What about my problem.
I have 4 cut areas and 10 surfaces. Changing stations at sample lines doesn't work.
Do You have solution?
I'm attaching the file.
EL CORREDOR HASTA EL FONDO ES DECIR TODA LA ZANJA Y EL CORREDOR HASTA EL LIMITE SUPERIOR DE LA CAMA DE GRAVA
