Just Putting the question out there to see if FDOT will be putting out a Stake Kit for Civil 3d 2015 or will I be able to use the 2014 state kit if I Install 2015?
We are finnaaalllllyy upgrading to 64 bit machines and will be upgrading from 2012 to what ever works with the latest FDOT statekit.
Jim Anderson
Volusia County Public Works
To ashamed to say current computer specs.
Solved by Cadguru42. Go to Solution.
FDOT has just started investigating 2015, we are in the process of getting our first update out for our 2014 Statekit (should be in the next week or two). If we do move to 2015 I would say it would be at least 6 months away.
@michael.robertson wrote:FDOT has just started investigating 2015, we are in the process of getting our first update out for our 2014 Statekit (should be in the next week or two). If we do move to 2015 I would say it would be at least 6 months away.
I'm curious as to how FDOT has been handling the flaws with QTO. How did they handle the lack of volumes and areas being incorrectly computed by the default installation?
FDOT is still doing quantities by Plan Graphics (not model) for both C3D & Geopak. We wrote our own Quantity TakeOff program which will come out in the upcoming release. So far via testing we are getting good results.
Thanks Michael.
As always you guys are right on it.
Jim Anderson
