What is the process to flip dimension arrows in 2010/2011. In LDD, all I had to do is select the dimension, right click and the option was available. I don't see it in 2011. Thanks.
Solved by mathewkol. Go to Solution.
I'm not sure what you mean by "flip the dimension arrows"? Picture?
Reid
It's a CUI thing. The AutoCAD contextual menu is defined differently for DIMs that the Civil CUI. You can copy it from the ACAD partial CUI. But you have to copy it to the main Civil.cuix file. I haven't found a way to do this with my partial CUI.
Or typw the command:
aidimfliparrow
Matt,
I haven't tried the CUI, but the command worked exactly as I wanted. Thanks for the quick response.
