I have a files with the extension (*.sid).
In previous version of AutoCAD Civil 3D 2010, after installing the AutoCAD Raster Design Object Enabler, I could see these files and work with them.
Today in the Current Version AutoCAD Civil 3D 2011, until now Autodesk not published AutoCAD Raster Design 2011 Object Enabler.
Is there a way to work with these files, or if there a way to convert them to another format allowing AutoCAD Civil 3D read.
i"m interested in receiving an explanation on how to fix this issue.
Thanks in advance.
Solved by rnoyes. Go to Solution.
I am pretty sure the Raster Design Object enabler is now available. Check this link see if it is what you are looking for, they have 32 and 64 bit installs available.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240618&id=15201709&siteID=123112
