Civil 3D Forum
Finding the intersection between two surfaces
7 REPLIES 7
Message 1 of 8
ignich
13205 Views, 7 Replies
I know that I am stretching the limits of Civil 3D 2011 with this request but I wanted to check to see if it could be done.  I have several surfaces, each defining a bedding plane in rock.  Additionally, I have a surface defining the project excavation. I need to find some key points (x,y,z) where the existing surfaces intersect with the excavation.  I have tried to paste one surface into another but I am not able to snap to any points on the surfaces to give me coordinates.
Any ideas?
Thank you.
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: ignich
Volume Surfaces, the 0 elevation is the point of intersection between 2 surfaces. Create a surface style that shows just User Defined Contours, set the surface's UDC's to use just the 0 elevation, extract the UDC's. Do this for each pair of surfaces you wish to examine.
Message 3 of 8
neilyj666
in reply to: ignich
There's also minimum distance between surfaces - outputs a series of lines in 2011 but a polyline in 2012 - which may be a better option
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 8
neilyj666
in reply to: ignich
....and these lines can be joined and converted to features to get the z value from the excavation surface.....
Message 5 of 8
ignich
in reply to: ignich
Thank you for your help.  I did find success using the minimum distance between two surfaces command, but only because I wasn't clear on your procedure.  It sounds like a handy solution to have available and I would like to learn the procedure to use in the future. I will have a look in the Users Guide for more information on the process.  Thanks again.
Message 6 of 8
peterfunkautodesk
in reply to: ignich
The lines in 2011 and the polylines in 2012 are 3D at the elevations of intersections.
Cheers,
Peter Funk
Peter Funk
Message 7 of 8
neilyj666
in reply to: ignich
I seem to remember that the lines in 2011 were only really of any use as a visual clue to the interface of two surfaces whereas the polyline in 2012 is much more useful
Message 8 of 8
Dexterel
in reply to: neilyj666
I posted an idea that may help (see link). If you feel is useful please support it.
http://forums.autodesk.com/t5/autocad-civil-3d-ideas/past-one-surface-into-another-with-a-top-or-bot...
Rail Community
