Civil 3D Forum
Find path of determined slope along a surface
3 REPLIES 3
Postmaster_G
992 Views, 3 Replies
So I am trying to draw an alignment for a road.  I want the alignment to represent the outside of the curve as the road climbs up and around a mound. Is there not way to do this in Civil 3D?!?
I have read this post
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/How-to-draw-a-3d-pline-at-a-designed-grade-on...
and this post
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Feature-Line-at-Grade/m-p/1533814/highlight/t...
and now I am thinking I will have to do this manually, extract contours, and trim/extend my way to victory...
I really would like to have this in a dynamic situation so I can make adjustments.  Also, it would be adventageous to have the line actually follow the grade so I dont have to add curves in etc later...
I do not have money to spend on an add on, I wish I did!
-Meow
3 REPLIES 3
TerryDotson
in reply to: Postmaster_G
For those that would consider an add-on, follow this link.
Autodesk Exchange Store - GradePoly
Neilw_05
I've dealt with this scenario more than a few times. You won't find a dynamic solution. Terry's tool is probably the best option. Use it as a guide to layout an alignment. Once you have the alignment you can run the tool with different parameters to make adjustments.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Postmaster_G
in reply to: TerryDotson
I appreciate this response, except I clearly state I do not have the money for this add-on.
When I do, I will most likely purchase this as it seems very useful.
Here is an idea.  I would pay twice as much for an add-on that would consider this situation:
...So I want my outside edge of road to ride the slope at x%.  I want my road to have a fixed width. I want the inside of the road to also be at x%.  I would like my minimum turning radius to be y-distance. Press go and it will give the required centerline and edges of road.
The cost of the add on being near 1% the cost of the program is not bad at all, 60 bucks is a bit steep for one feature though...
I wish guys like you worked for autodesk so this would just be in the program.  That or they should totally buy this from you (guess they are cheap like me)!
-Meow
Rail Community
