There are MANY times that I need to find out the station and offset of a particular location but I don't want to show a label there. The only way I've found to do this is to place a station/offset label and then delete it.
Does anyone know of command that will allow me to use an osnap to find out the station & offset (such as wanting to know the station & offset of the end point of a line, location of a cogo point or center of a circle)?
TIA!
Don Ireland
Engineering Design Technician
Solved by Neilw_05. Go to Solution.
The inquiry tool.
OMG! Now that you say that, I remember the instructor quickly skimming over that. But I had forgotten all about it. I've always placed an SO label and then deleted it afterward.
THANKS!
Don Ireland
