I have a Centerline alignment with found Right-Of-Way corners. I need to compute the distance from the the nearest point on the alignment to each of the found corners. They are all within 1.5'. If possible it would be neat to know the distnace/bearing to each corner. Is there a way to do this?
Doing a Station/Offset report will tel you your distances, but there.s no functionality for bearings relative to your alignment. For this, you would have to draw a line from each point to the alignment, then add labels to the lines, and then you can create a table from your labels.
Why not just generate a label that will give you everything in one? You have both instantaneous direction and perpendicular direction. One will give you from the alingment the other from the world.
