Civil 3D Forum
Find offset to point from alignment
3 REPLIES 3
pdsfishhouse
385 Views, 3 Replies
I have a Centerline alignment with found Right-Of-Way corners.  I need to compute the distance from the the nearest point on the alignment to each of the found corners.  They are all within 1.5'.  If possible it would be neat to know the distnace/bearing to each corner.  Is there a way to do this?
3 REPLIES 3
Jeff_M
in reply to: pdsfishhouse
The Point Station Offset report will give you the offsets, but not the direction/distance.
owenmull
Doing a Station/Offset report will tel you your distances, but there.s no functionality for bearings relative to your alignment. For this, you would have to draw a line from each point to the alignment, then add labels to the lines, and then you can create a table from your labels.
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
kcobabe
Why not just generate a label that will give you everything in one?  You have both instantaneous direction and perpendicular direction.  One will give you from the alingment the other from the world.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Rail Community
