Civil 3D Forum
Find Layer within Style
5 REPLIES 5
JCyganiak
1936 Views, 5 Replies
Does anyone know a quick way to find a layer within a style. I have been changing layers in our Code Sets and I can't seem to purge out a specific layer. I'd rather not spend hours going through every single code again.
Joe Cyganiak
Civil Engineering Senior Designer
AutoCAD Civil 3D 2017
5 REPLIES 5
Neilw_05
in reply to: JCyganiak
You should have the Purge Styles command in 2012. It is found in the manage panel of the ribbon.
You may also find useful tools for managing styles in SincPac (http://www.quuxsoft.com), a robust set of custom tools for Civil 3D.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Neilw_05
in reply to: Neilw_05
I'm afraid I missed a key part of your post. You don't want to purge the styles, just the layer used in a style. I don't know of any way to find where the layer is used, but a workaround is to merge the unwanted layer(s) to a layer you want to keep or to layer zero. Then you can purge the unwanted layer(s).
WIN 10 64 PRO
JCyganiak
Thank you! I will look into it. I'm actually trying to convert a assembly to new layers that were created and i can't find one of the layers that i can't purge.
Joe Cyganiak
Jeff_M
Actually, Neil, you had already mentioned SincpacC3D which has such a tool:
CivilStyleProperties
Neilw_05
in reply to: Jeff_M
I figured you'd have a tool for that but I didn't know for sure.
WIN 10 64 PRO
Rail Community
