New to C3D 2014 and setting up Survey to import text files.
After importing the survey data (csv file) sometimes there are typos or items are mis-coded.
Question -
What's the best way to replace 25 instances of survey code BLCK with BLK?
I know I can edit the points/codes individually, and that's fine for a few typos, but is there
some kind of find and replace available?
Tom F.
Solved by IanMcClain. Go to Solution.
Try creating a Point Group with the bad code, go to point list, right click on the Point Description and edit and change them that way.
If you right click and choose to edit points from the prospector or a survey database, you can sort by description. Find your group of points and select them, then right click the column heading and choose edit; you will get a cursor over the first one in the list. Enter/edit your code and then hit return and all the selected points should change in one whack.
