Civil 3D Forum
FIlling gaps in a surface
7 REPLIES 7
Message 1 of 8
dibr0804
16915 Views, 7 Replies
Is there a way I can fill the gaps in this surface? The surface is a combination of four pasted surfaces with boundaries set so they dont overlap on each other and create a mess.. I can't have these holes/slivers in it because SiteVision wont accept it.  So basically is there a command that will fill the gaps in for me?
7 REPLIES 7
Message 2 of 8
dibr0804
in reply to: dibr0804
I know I can go and draw breaklines in and add them to the surface but is there an easier faster way?
Message 3 of 8
dibr0804
I figured it out... created a "show" boundary around the extents...
Message 4 of 8
Joe-Bouza
have you tried adding a "Show" boundary?
Your Name
Your Name
Message 5 of 8
fairhilleng
Would you be able to share the steps required to "show" boundary to fill gaps?  Thank you.
Message 6 of 8
neilyj666
in reply to: fairhilleng
Draw a polyline around the area with the gaps, Modify Surface, Add Data > Boundaries and change the boundary type to Show. I also have my template set up with several Boundary Layers set to NoPlot
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 8
Instead of drawing polylines around gaps, you can just extract boundaries of these gaps and add them as surface "show" boundaries.
Message 8 of 8
myke
In edit surface, add a surface point (not a cogo point) to the midpoint of one side of your gapped triangle.  Use snap to midpoint, and it will suggest the relevant elevation.  The surface will rebuild across the gap.  Now, optionally, in the edit surface tools you may remove the helper surface point.
Rail Community
