Valued Contributor
bthomas9120
Message 1 of 6 (194 Views)
filename at top of screen
194 Views, 5 Replies
12-20-2012 08:43 AM
I have a user that has the incorrect filename show up the top of the screen sometimes. Only with more than 1 drawing open of course and not all the time. Anyone ever seen this? civil 3d 2011. Meaning if he has drawing2.dwg open it might still say drawing1.dwg at top. make sense?
troma
Message 2 of 6 (192 Views)
Re: filename at top of screen
12-20-2012 08:46 AM in reply to: bthomas9120
Yes, this has happened to me.  Quite disturbing.
Credit where credit is due! Give kudos or accept as solution whenever you can.
*Pro
dgordon
Message 3 of 6 (179 Views)
12-20-2012 11:35 AM in reply to: bthomas9120
normally doint a quick save will fix the display issue.
it's just remembering the previous filename you did a save as from.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
bthomas9120
Message 4 of 6 (174 Views)
12-20-2012 11:40 AM in reply to: dgordon
Thanks for the input. I figured out how to get it right...jsut didn't know if there was an actual fix. Minimizing the drawing, or exiting autocad will do it also. Problem is, some of these guys don't save very often. Then they do a saveas and.....you get the rest of the problems that can occur when they look up at the filename and decide from that wether or not to save a drawing before closing. Anyway, thanks.
Valued Contributor
C3D_TomR
Message 5 of 6 (154 Views)
12-20-2012 01:20 PM in reply to: bthomas9120
I see the issue quite often too using Civil 3D 2012. I can't quite duplicate it, but it seems to happen most often when I qsave a large drawing then use CTRL+Tab to switch between drawings while the drawing is still being saved to the network. It happens so often that I typically check Toolspace to verify which drawing is actually current.
Valued Contributor
bthomas9120
Message 6 of 6 (151 Views)
12-20-2012 01:23 PM in reply to: C3D_TomR
My guy here sees it when he is using ctrl tab to switch between drawings as well. That must have something to with it.
