Is there a way to detect in what CAD version a file is saved?
That must be a way without opening each file and reading the command line!
Personally I think it should be shown in file properties but it does not!
(Opening the file in Notepad and reading the first row is a solution but it must be easier than that!!!)
Solved by abubakars. Go to Solution.
You've already found the only way I know how to do it.
You can use BatchInEditor or BatchInDatabase tools to identify the last saved drawing version, Either add the files to the drawing list or drag and drop to drawing list which instantly show all the added drawing version.
The tools are very powerfull for batch operations and available to donwload from Autodesk exchange Apps and it is FREE.
