Civil 3D Forum
File Size Increases After Save
5 REPLIES 5
htls69
1593 Views, 5 Replies
so i am using civil 3d 2012 with all updates installed (win7 x64 with all updates)
i open a file that another user has created and the file size is 2.2 mb
alll i do is a save after opening it and the file size jumps to 51.8 mb
Allen Robberson
Credit where credit is due! Give kudos or accept as solution whenever you can.
5 REPLIES 5
tcorey
in reply to: htls69
Is this still the case after you have exited AutoCAD or only after saving, but AutoCAD is still open?
Is ISAVEPERCENT set to something other than 0?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
htls69
in reply to: tcorey
this is even after exiting autocad and closing the file
the ISAVEPERCENT set to 0
i had another coworker open the smaller sized file and resave it and it does increase to 16.5 mb but not the 51 mb like mine
Allen Robberson
tcorey
in reply to: htls69
Are the files a different version before saving?
What if you set Proxygraphics to 0?
Tim Corey
Redding, CA
htls69
in reply to: tcorey
so setting the  Proxygraphics to 0 seems to fix the issue
it is back to the 2 mb size now thatnks that is awesome
Allen Robberson
Nilesh_Chaudhari
in reply to: tcorey
I am facing the same issue. Both values are set to 0 but it didn't work.
Nilesh Chaudhari
Product Support Specialist
Rail Community
