I am using AutoCAD Civil 3D 2009.I have a project files suddenly file size becomes @ 10 MB after saving. Even Titlblock size is 7 MB.
I had installed a latest update over my system as well i tried to clean a file as per below thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/File-size-and-performance-issues/m-p/2800660#M139135
After doing this file size reduced to KB. But if open it again and saved then file size go to MB.
Is there anyway to fix it??
We need to fix it asap..so plz help me.
Thanks in Advance.
Solved by SethHall. Go to Solution.
Hi YM_99-
Did you install that Hotfix Almas mentioned in his post? If not, that would be ths first thing I would suggest trying. Here is the link: http://usa.autodesk.com/getdoc/id=DL15412532
Hope this helps!
