Civil 3D Forum
File Size Increases After Save
2 REPLIES 2
3196 Views, 2 Replies
I am using AutoCAD Civil 3D 2009.I have a project files suddenly file size becomes @ 10 MB after saving. Even Titlblock size is 7 MB.
I had installed a latest update over my system as well i tried to clean a file as per below thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/File-size-and-performance-issues/m-p/2800660#M139135
After doing this file size reduced to KB. But if open it again and saved then file size go to MB.
Is there anyway to fix it??
We need to fix it asap..so plz help me.
Thanks in Advance.
2 REPLIES 2
SethHall
Hi YM_99-
Did you install that Hotfix Almas mentioned in his post? If not, that would be ths first thing I would suggest trying. Here is the link: http://usa.autodesk.com/getdoc/id=DL15412532
Hope this helps!
Seth Hall
Product Owner
Model Builder
in reply to: SethHall
hi Seth...
thanks a lot....it solves the issue....
Rail Community
