This issue begins when I use the "aectoacad"-command.
The file that I get is rather small. Saving the same file after using audit and -purge commands will make it larger, I don't get it.
I've seen a hotfix but I already have the latest update: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15413300&linkID=9240698
Anyway, help is appriciated.
Sincerely
Solved by mathewkol. Go to Solution.
What happens if you insert the entire drawing into a stock template such as acad.dwt? Does the same issue occur?
Have been done some testing with a random model. I don't know if it's helpful.
Civil 3d model - > aectoacad = simplified model, file size = x
simplified model - > save as (e.g., new file name), file size = 2x
simplified model - > audit, -purge - > r, -purge - > a, file size = 2x
simplified model - > pasted into acad.dwt - > save as, file size = 2x
This is a problem when I'm working with larger drawings.
Sincerely
I didn't know that, it's simple but not expected.
Thank you!
Sincerely
