Does anyone know how to set the drawing file path so it shows up at the top of my screen when I am in an autocad session? Currently all I see is "Autocad Civil 3D".......thanks
Solved by Jay_B. Go to Solution.
Sure, Options>Open & Save Tab>check "Display Full Path in title" on upper right of dialog.
neilyj (No connection with Autodesk other than using the products in the real world)
Interesting, seems to stay here, always launch via a desktop icon using a profile switch which loads our custom profile.
Sorry, I'm not aware of any command or setting variable controlling this.
If it helps I was able to find the value in the registry HKEY_CURRENT_USER>Software>AutoDesk>version #>Profiles>Profile Name>General>ShowFullPathInTitle
