Civil 3D Forum
file path visible on top of autocad window
5 REPLIES 5
wbrustle
5641 Views, 5 Replies
Does anyone know how to set the drawing file path so it shows up at the top of my screen when I am in an autocad session? Currently all I see is "Autocad Civil 3D".......thanks
5 REPLIES 5
Jay_B
in reply to: wbrustle
Sure, Options>Open & Save Tab>check "Display Full Path in title" on upper right of dialog.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
wbrustle
in reply to: Jay_B
thanks so much!!!!...I knew it had to be somewhere:)
neilyj666
Do you know the command line version of this to put in my acaddoc.lsp - it seems to reset itself after a crash
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Jay_B
in reply to: neilyj666
Interesting, seems to stay here, always launch via a desktop icon using a profile switch which loads our custom profile.
Sorry, I'm not aware of any command or setting variable controlling this.
If it helps I was able to find the value in the registry HKEY_CURRENT_USER>Software>AutoDesk>version #>Profiles>Profile Name>General>ShowFullPathInTitle
C3D 2018.1
C3D 2016 SP4
neilyj666
in reply to: Jay_B
Thanks for this - it's no great hardship just resetting from OPTIONS so I can continue do do this
Rail Community
