In Civil 3d 2011 I have always used the windows start menu file history to open recent documents. Its no longer populating that field, but other windows applications are. Has anyone else ever experienced this?
Solved by Chaznsc. Go to Solution.
Check options for recent dwg list.
(see attached).
If you right click in that "recent" drawing area, it shows "properties" which should have 2 check boxes in the Start Menu tab, that should be checked. If they aren't, you may have recently changed some privacy settings somewhere else that unchecked them?
I reset the jumplists in windows and its fixed........below is a link for future reference:
http://www.sevenforums.com/tutorials/81483-jump-lists-reset-clear-all-items.html
