To expand on Matt's information.
The figure is effectively a collection of lines (arcs) joining points.
When you add it to a surface model, the elevation data will come from
the point elevations and if you added as a break line, then the lines of
the figure will be used to preclude surface triangles crossing the
figure. If a firgure is not set as a break line, then for all practical
purposes it only adds the point data to the surface model
When a figure is place in a drawing it has a display style. The style
may tell it to display as 2D or 3D. Either way it is still the same figure.
Laurie Comerford
Matt Kolberg wrote:
> I will use the true value regardless of your style settings.
