Civil 3D Forum
FG Profile Parabola through VBA
1 REPLY 1
176 Views, 1 Reply
Trying to add a FG profile to an alignments profiles collection, I succeed
if what I add are aeccProfileTangent PVIs
But receive an error message if I try to add aeccParabola PVIs.
The code I´m using reads:
Set oPerfil = oPerfiles.Add("TestProf", aeccFinishedGround, "Design Style",
0#, 999.585, "01-TEST")
Set oPerfPVIs = oPerfil.PVIs
Set objPVI = oPerfPVIs.Add(0#, 661#, aeccProfileTangent)
etc..
But when trying to call:
Set objPVI = oPerfPVIs.Add(40.000807, 661#, aeccParabola)
I get the following message error
Run Time error:
'-2147024809 (80070057)':
El parámetro no es correcto (which means "the parameter is not correct")
(Note: I am running Civil 3D on the spanish version of Windows XP)
The FG profile created with aeccProfileTangents can be edited afterwards,
manually adding the parabolas.
The Add method for AeccProfilePVIs is not adequately documented as there is
no explanation to what the two optional parameters Param1 and Param2 may be.
Maybe that could be the problem, albeit those parameters are supposed to be
optional:
Public Function Add( _
ByVal Station As Double, _
ByVal Elevation As Double, _
ByVal CurveType As AeccProfilePVICurveType, _
Optional ByVal Param1 As Variant, _
Optional ByVal Param2 As Variant _
) As AeccProfilePVI
Thanks in advance,
Reinaldo Togores
University of Cantabria, Spain
1 REPLY 1
Just in case it's useful to someone else, I'll answer myself... Just found
out how!
Parameter1 for a parabola should be the curve length.
Procedure should be to add first the two endpoints of the profile with
aeccTangent PVIs. Afterwards include the intermediate parabolas.
Best regards,
Reinaldo
"R. Togores" escribió en el mensaje
news:4855569@discussion.autodesk.com...
etc..
Run Time error:
optional:
) As AeccProfilePVI
Thanks in advance,
Reinaldo Togores
Rail Community
