Civil 3D Forum
FG for Dredging
3 REPLIES 3
kerksieck
566 Views, 3 Replies
FG for Dredging
I am trying to create a FG surface for a dredging project. I've made a corridor representing the maximum elevation that the channel can be; in some areas it is cutting and in some areas it is filling but I really only want the cut to show up on my FG.
Is there a way to build an assembly that will result in a corridor that only cuts or, alternatively, is there a way to define a new surface that looks at two source surfaces and takes the lower elevation?
Note that at a given station, there may be both cut and fill at different offsets so I don't think using, say, a ditch subassembly would work since it checks for cut/fill at only one offset (at least as I understand it.)
Thanks for the help,
-D
3 REPLIES 3
kerksieck
in reply to: kerksieck
another thing:
extracting polylines from a volume surface to create boundaries and pasting the results together is not really satisfactory as it is not dynamic.
cmbarrett1
I know it's been a while since you posted this question but, I'm having the same problem and looking for an answer.  Did you ever find a solution?
Craig
Joe-Bouza
in reply to: cmbarrett1
I don't have the full picture but it seems the me the profile grade line controls the cut. How does you corridor end in fill?
Joe Bouza
Rail Community
