Mark Green
Working on Civil 3D in Canada
"why would I select a profile"
Select a profile to label the high and low points from that profile, along the alignment in plan.
"when I select add/edit station label. there is NO 'component' category"
You must add the component to the label in the label editor. Then you can add the label to the alignment. (Then you must assign the profile to the label.)
Mark Green
Mark Green
