Hey guys.. This one has me stumped..
I have developed a nice custom subassembly and everything models they way i want it to.. However i am having problems with my feature lines when the meander either side of the centreline. they dont stay together! which makes it really anooying if i want to create a boundary on a surface.
Here is the section. A basic dam with multiple stages incorporated. The crest width of the stages can vary.
The problem becomes more obvious in plan view
you can see the pink line is my daylight string. But when it crosses my centreline it stops and starts again!!
extremely annoying as i can;t pick it as a surface boundary automatically! i have to pick and find all the gaps interactively.
Any ideas?? is their setting i can toggle to allow features line to join on either side of the centreline.
cheers.
Kapanther
Solved by ceethreedee.com. Go to Solution.
I ask these questions because I'm assuming the answer to #2 is YES. If that's the case, that's most likely the problem.
Post your subassemly. Keep in mind that this website will not allow you to upload a PKT file -- rename it as a zip and then post that. When it gets downloaded we'll save it as a pkt file.
Don Ireland
Engineering Design Technician
This behavior is a confirmed defect that was introduced in C3D 2014.
Doni...
no it is all one subassembly... the alignment is blue... one i nthe middle
Kapanther
anyone know if this has been fixed in 2015 sp1?
No and it is frustrating. We need this capability to create Left Turn lanes ASAP.
Man.. awful. That is a deal breaker for me. Looks like its back to 12d.
I am right in saying that it used to work yeah? I think 2012 it was fine?
My company is now on a new agreement with autodesk. (platinum Support). I posted this issue to them. got this answer back
Really hoping it means that something might be done about it!
Hi Brad,
I've had a very detailed look into your case, as have the wider Civil 3d support specialists. This is quite concerning behavior, especially due to the impact on modeling Median strips. I have raised it as a Major Defect with our development team (email to follow), hopefully it will be addressed soon. I'll update you as and when I get an update.
Best regards,
Autodesk Support Team
They have been working on this for quite awhile. You are probably talking to first tier support here...
The latest update I have gotten from Dave Simeone is that they are "proceeding cautiously" with the repair due to the inherent complexities invoved with the corridor logic involved when crossing centerline.
More bees = more stings.
Fixed in 2017
