I'm building proposed surfaces for sidewalk ramps, and the process I'm following is to use featurelines to model the ramps, then add the featurelines to my FG surface as breaklines. In cases where the featurelines have arc segments, the surface triangulation is not as good as I'd like it, so I've been using the 'Supplementing factors' settings to try and force the level of triangulation I want, but occasionally it isn't to my liking and I want a 'do-over'. I want to delete the featureline from the surface definition, then re-add it using a lower mid-ordinate distance.
The surface->breaklines entry in the Prospector will show me a list of the breaklines in my surface definition, but it only shows them by name and number of vertexes. Short of deleting a featureline and recreating it, how can I just remove a featureline from a surface definition? If I right-click an entry in the prospector, there's an option to select it, but all that does is select the entire surface, not any individual breakline.
Solved by Jeff_M. Go to Solution.
LIst the featureline, the output will tell you which surface it is used as a breakline in, if any, and the breakline name. Note the last entry below, it is breakline number 7 in the Pit Entrance Breakline group, of Surface FG
AECC_FEATURE_LINE Layer: "C-ANNO" Space: Model space Handle = 17bf4 Site : Site 1 Style : Basic Feature Line Points : 4 2D Length : 83.686' 3D Length : 83.716' Elevation Range : 304.87' - 306.46' Grade Range : 0.25% - 4.28% Breakline Data : FG, Pit Entrance: 7
Your Name
Your Name
Your Name
Your Name
