*CivilEITGuy
Message 1 of 3 (123 Views)
Feature Lines
123 Views, 2 Replies
12-04-2008 08:35 PM
In LDT I would create 3D Polys (by Elevation) and select ".G" at the prompt
for points to select the AEC point object. That way the 3D poly will
automatically grasp the elevation, then I would type ".G" again to exit the
prompt. Is there a way to do this with feature lines in 3d? When I draw a
feature line and type .G or .P, nothing happens. Or do the points need to
be at actual elvations?
Thanks in advance.
Active Contributor
quannguyen
Message 2 of 3 (123 Views)
Re: Feature Lines
12-05-2008 01:23 AM in reply to: *CivilEITGuy
In Civil 3D you should use the Transparent Commands; for example '_PO for points. It is more convenient to turn on the Transparent Commands Toolbar and use the transparent commands from those tools.
*Pro
dgordon
Message 3 of 3 (123 Views)
Re: Feature Lines
12-05-2008 05:16 AM in reply to: *CivilEITGuy
Feature lines have their own set of tools in a toolbar. Once you bring this toolbar up and see what is in it, you should have your answer.
Dan
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
