Civil 3D Forum
Feature Lines
3 REPLIES 3
Swanzo
175 Views, 3 Replies
Feature Lines
I have modeled a corridor, and now I want to export a feature line, but I can't seem to get them to generate!?!?
Suggestions?
Erik Swanson
Project Manager
David E. Ross Associates
3 REPLIES 3
in reply to: Swanzo
Erik,
Are you finding that you cannot select the feature line? Does the command
Export > Corridor Feature line as polyline work? Does the Corridor have
multiple baselines?
Dan
wrote in message news:4857710@discussion.autodesk.com...
Suggestions?
Erik Swanson
Project Manager
Swanzo
in reply to: Swanzo
Background:
I have a corridor with a cul-de-sac at the low point. Since I want to keep the vertical alignment of the centerline, I used the basic lane transition to stretch out to the curbline. I have also defined an alignment along the c-d-s curbline.I want to export the feature line @ ETW as the vertical alignment component (profile) for the curbline - then attach an assembly for the curb/sidewalk around the c-d-s. I added the ETW feature line in the Surfaces tab of the Corridor properties dialog box.
When I rebuild the surface, I can't select the feature line...
tscheevel
in reply to: Swanzo
Have you exported the surface using the "Corridor> Export" tool. If so, turn off the layer with the exported surface on it and try to select the feature line. I ran into this yesterday when trying to create a "Render Only" boundary on a corridor that I had just exported the surface from. It seems that the surface breakline was on top of the corridor feature line and when I tried to select the feature line I got a command line message that said "No feature line selected". I deleted the surface from the surface collection then it worked fine. I would assume that turning off the layer would save you having to delete the surface.
Rail Community
