I have been having an issue extending feature lines the last while. I was able to do it before but now I think a system variable changed that won't let me extend them. I have tried setting "Edgemode" to both 0 and 1...with no solution. As I said I used to be able to extend them simply by drawing a line before and using "Extend" as I would a regular line or polyline.
Any ideas?
Solved by jbalaneski. Go to Solution.
Found the solution...It's the "PROJECT" option under the "EXTEND" command options.
Which setting worked and which one didn't?
Thanks!
Mark Green
Working on Civil 3D in Canada
I tried all the options in the "PROJECT" variable...and they all worked except the "None"
