Civil 3D Forum
Feature lines, surfaces, and Object Viewer
2 REPLIES 2
jeff_rivers
341 Views, 2 Replies
When I use Object Viewer to look at just featurelines and surfaces, the featurelines do not appear at the same elevation as the surface as I shift the view around.  Why is that- especially since I am looking at the surface I created from those same featurelines?
is that a feature, intended to make it easier to discern the featurelines in Object Viewer?  Or a quirk of my video card?
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
2 REPLIES 2
in reply to: jeff_rivers
Check the Triangles tab of the Surface Style.Make sure that 'Use Surface Elevation' is selected.
If thats not it check the 3D Geometry tab of the survey figure styles and make sure that 'Use Surface Elevation' is selected.
jmayo-EE
Along with Caleb's good advice, I would also check your surface edits. You may have accidentally moved the surface up.
John Mayo
Rail Community
