Civil 3D Forum
Feature lines losing intelligence when I reopen file
6 REPLIES 6
rwolfe00
440 Views, 6 Replies
I am using the AutoCAD Civil 3d 2014 version.  I have created a small site using the surface.dwt template located in the tutorials.  The surface is created using COGO points for existing surface and using only feature lines for all proposed since it is a small site and has irregular features, roads and lots.  I created the grading using the feature lines or along feature lines and everything worked out well.  I saved the work and closed the drawing.  The same day I opened the drawing to find all of the feature lines have turned into polylines.  I tried the file recovery, but since all of the work was in the same day, it didn't have the created feature lines and grading.  I recreated all of the feature lines and when I tried to use the grading tool, it would crash the program repeatedly this time around and still have the same issues.  I now have recreated the feature lines once again.  Before I try grading again and chance redoing the work again, does anyone have any thoughts or advice into what I'm doing wrong or if it is a fix that needs updated to the program?
Robert
6 REPLIES 6
owenmull
in reply to: rwolfe00
Could you post the drawing?
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
rwolfe00
in reply to: owenmull
I am unable to post the drawing.  Is there any additional information you need about the way the drawing was set up?
ericcollins6932
Check your settings; sounds like CAD is set to save to vanilla cad or a previous version?
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
rwolfe00
My save settings are set to 2010 version.
owenmull
You can post the drawing if you make a copy of it, then via Windows change the file type extension to something like '.txt' and upload it.
-Owen
Windows 7 x 64 bit
Civil 3D 2017
rwolfe00
in reply to: ericcollins6932
I changed the save settings to 2013 and it has fixed the issues.  Go figure it's a simple fix.  I wouldn't have thought there would be that much difference.  Thanks!
Rail Community
