You can explode them to 3dPolys, or you can add elevation points to the
'back of curb' feature line, adjusing as required for the cuts. If you add
points to the back of curb, you'll probably want to add points in the same
spot along the 'bottom of curb' one as well (if you're taking it to that
level, it's worth the extra couple of seconds).
wrote in message news:5524513@discussion.autodesk.com...
I am trying to use feature lines to create curb for breaklines. The reason
is, that it is the only way to have curved breaklines with elevations. Also
it makes it easy to create curb by offsetting the feature line and raising
the entire line by the height of the curb.
So, the problem arises when I have curb cuts for driveways. The easiest
method would seem to be trimming the 'back of curb' line at the curb cuts,
however feature lines don't seem to allow trimming, breaking, or any other
horizontal manipulation.
ideas?
