Valued Contributor
el.Topo
Message 1 of 3 (342 Views)
feature lines - arc segment fillet
342 Views, 2 Replies
11-26-2012 05:02 AM
I create a feature line including some arcs. While editing I need to redimension the feature line, but the arcs will lose tangency. Therefore I have to break/trim/delete/manually edit the tangents until they intersect and then FILLET them to get a new arc. I tried EDIT CURVE with 0 Radius but it's not acceptable. Any workaround on this one (filleting feature lines like polylines or a closing option)?
Thank you
MacBook Pro, Intel Core i7 CPU M 620@2.67GHz, 8GB RAM
W7Pro SP1, 64-bit / Civil3D 2013
vk,
by re-dimensioning the feature do you mean changing the size of a radius of one of the curves?
if so the edit curve command for feature lines works.   if you want a zero radius there is a delete option to get rid of the curve which will replace the curve with a zero radius fillet.   If you have a zero radius fillet and wish to add a curve then the fillet command can be used to do this.
I don't understand when you say that the curve looses tangency.   They don't appear to do that at all for me.
thank you!
it's this "Delete" option I could not find that solves my problem.
:smileyhappy:
*Pro
dgordon
Message 2 of 3 (337 Views)
Re: feature lines - arc segment fillet
11-26-2012 05:36 AM in reply to: el.Topo
vk,
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
el.Topo
Message 3 of 3 (334 Views)
11-26-2012 05:43 AM in reply to: dgordon
thank you!
:smileyhappy:
