is it possible to join 2 feature line? thank all you
Solved by dgordon. Go to Solution.
...and if I can add a bit to the solution above, you can also join a 2d or 3d polyline to a Feature Line with the same command if Z is the same on both entities at the join point.
This can help with managing a surface's build order since it is easy to get breakline data into a surface at the same place in the build using JoinFeatures.
John Mayo
