Civil 3D Forum
feature line.
3 REPLIES 3
mziani
303 Views, 3 Replies
feature line.
is it possible to join 2 feature line?  thank all you
3 REPLIES 3
dgordon
in reply to: mziani
yes, in the feature line edit tools there is a join feature line command. the two feature lines have to have the same elevation at the shared join location.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
jmayo-EE
in reply to: dgordon
...and if I can add a bit to the solution above, you can also join a 2d or 3d polyline to a Feature Line with the same command if Z is the same on both entities at the join point.
This can help with managing a surface's build order since it is easy to get breakline data into a surface at the same place in the build using JoinFeatures.
John Mayo
mziani
in reply to: jmayo-EE
thank....
Rail Community
