The dwt Template file "_AutoCAD Civil 3D (Imperial) NCS Extended" includes
the "Grade Check" Expression. IOW, if you don't have the option for the
slope, you will need to create your own Expression. Here is the formula
needed:
IF({General Segment Grade}<0,0,pi)
wrote in message news:5638094@discussion.autodesk.com...
That was fast jeff!
And it's just what I was looking for, however... when I go into the label
style composer I can't select "Grade Check" in the rotation angle box of the
arrow component. All I can do with it is to type in an angle or select one
on-screen.
Any clues?
