I have a feature line that I want at a constant elevation and it is going to be part of a new surface. I want to grade 4:1 to the eg surface. The feature line is interacting with the eg surface in that it is geting more elevation points. I want it not to interact with the eg except to grade to the surface. Do I want the eg surface on the same site or a different site as my features lines? If it is on a different site will it still grade to the eg. How can I put my eg on a new site. I can't find what site it is on?
Surfaces are not on sites.
If you created your feature line from objects, and you told it to Assign Elevations, there was a check box to Insert intermediate grade break points. This will add more elevation points along the feature line.
Tim
Feature lines of the same Site will interact with each other, meaning that two feature lines at different elevations that "intersect" in plan view will interact with each other. As you saw, the most recently edited feature line holds. So, at this "intersection," the first feature line behaves as if it was "stapled" to the most recent one. To avoid this, place the second feature line in it's own Site, reset your elevations, and then simply grade to surface.
As tcorey stated, surfaces are not contained in Sites. Sites contain Alignments, Profiles, Feature Lines, Grading Groups, and Parcels.
