Civil 3D Forum
Feature Line from Grading
9 REPLIES 9
Message 1 of 10
neilyj666
8028 Views, 9 Replies
I created a grading but now I want to use the "daylight" line (as a featureline) and delete the grading (due to stability problems I was having yesterday (C3D hung for 2.5hrs, I went home and VPN'd into my work PC).
Can the daylight line be extracted without exploding the grading as I'd prefer to delete the grading via the Delete Grading on the toolbar as this seems to be more robust than trying to delete the exploded entities??
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
9 REPLIES 9
Message 2 of 10
JeffPaulsen
in reply to: neilyj666
I do not know how to extract the daylight line but I have had very good success exploding the grading by selecting the daylight feature line. If I select other portions of the grading when exploding I get less than desirable results. AS you probably know after exploding you are left with a 3d polyline. I like to turn that back into a feature line.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Message 3 of 10
neilyj666
A new command "Extract feature line from grading" is what's required.....
Message 4 of 10
JeffPaulsen
I second that. I would have used it 5 times already today.
Jeff Paulsen
Message 5 of 10
Jeff_M
in reply to: JeffPaulsen
If it's something you use often, perhaps a little Third Party help would be in order?
Message 6 of 10
neilyj666
in reply to: Jeff_M
Not able to buy anything unfortunately but there are a whole raft of addons in the Sincpac that offer functionality that really should be included as part of the core C3D product....but isn't
Message 7 of 10
NathanBee
Save drawing, explode, copy to coordinates (say, 0,0), close, re-open drawing, paste (to 0,0), convert polyline to featureline.
Then just Delete Gradings.
Cat Wink
Message 8 of 10
Nbondy
Use the stepped offset command, and offset it a very small distance (0.001).
Message 9 of 10
sboon
Select the Daylight Feature line, right-click and use the Move to Site option.  This method will delete the grading object, or you can use the Copy to Site command if you want to keep it.
Once you have cleaned up the grading objects you can move the daylight features back to the original site.
Steve
Expert Elite Alumnus
Message 10 of 10
neilyj666
in reply to: sboon
This looks like a good suggestion....Smiley Happy
I'm not keen on offsetting objects very small distances as it becomes a bit of a pain keeping track of them
Rail Community
