First, I'll make sure I understand the situation.
FL1 does not update to reflect the change in profile. Correct?
Did the corridor actually update? If no, rebuild the corridor.
If yes, does the original featureline within the corridor change and leave the extracted featureline unchanged?
Don Ireland
Engineering Design Technician
I just tried to reproduce the issue (at least as far as I understand it) and the only way I was able to do so was to set the corridor to NOT rebuild automatically.
When it is set that way (to rebuild automatically) and I change the profile, the linked featureline works fine.
In the following two screenshots, the yellow line is the extracted featureline (which is the daylight line) and the red line is a feature line created by using a grading object from the autofeatureline which grades to an elevation.
The difference between the two screenshots is that when I changed the profile, the corridor updated which updated the extracted featureline which in turn updated the featureline I created based on that. I used C3D 2014 SP2 for this test. I'll post the dwg for your reference.
Don Ireland
