Civil 3D Forum
Feature line flow arrow direction expression
11 REPLIES 11
Message 1 of 12
troma
3639 Views, 11 Replies
Here is my flow arrow and the expression:
Now, in my understanding, the flow arrow should either be rotated 0, or 180  (pi radians).  But clearly, some of them like to have their own mind about things, and decide on some other rotation.  It seems that on the steep slopes, the arrows go a bit skew.
A little more investigation:  I think the skew is related to the actual elevation difference of the segment, rather than the steepness of the slope.  A long segment with 15% slope has a worse skew than a short segment at over 30%, presumably because the elevation difference from the start to the end of the segment is larger.
Obviously, I would like all my flow arrows to be parallel to the feature line in plan.  Any suggestions?
Mark Green
Working on Civil 3D in Canada
11 REPLIES 11
Message 2 of 12
Ed.McGriskin
in reply to: troma
Interesting. I have a similar label with the same expression and I wasn't able to recreate what you have occuring. My guess would be either something to do with the anchor point or anchor component.
Ed McGriskin, P.Eng.
Project Engineer @ HUSSON
Remember to accept the solution so others can find the solution also.
Message 3 of 12
troma
in reply to: Ed.McGriskin
Are you using a 'Direction Arrow' component or a block as your flow arrow?  It works fine for me if I use a Direction Arrow, but I need to use a block.
Thanks.
Mark Green
Message 4 of 12
Ed.McGriskin
in reply to: troma
I just use the flow direction arrow.
What is the block anchored to? I created a quick block and anchored it to the direction arrow and with the rotation specified by the expression. I set the direction arrow display to false after. It seems to be working.
Message 5 of 12
troma
Beautiful!  I just had it anchored to <Feature>.  Something about that large elevation difference in the featureline throws it off, but anchoring to a hidden direction arrow is perfect, thanks!
Mark Green
Message 6 of 12
Ed.McGriskin
in reply to: troma
Anytime.
Message 7 of 12
dasindog
in reply to: troma
I know you've already found your solution but I use your originial idea and it worked fine with the only difference being the expression was formatted as a double not direction. Maybe that was just an oversight?
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Message 8 of 12
troma
in reply to: dasindog
Didn't make any difference here.  Maybe it's one difference between 2011 & 2013?
Mark Green
Message 9 of 12
dasindog
in reply to: troma
Quite possible. Anyway... at least you got what you wanted.
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
Message 10 of 12
kiss
in reply to: troma
Hello Gentlemans!
I have only one question about this topic, which is not clear for me, how/where do you add this expression to the label style?
I would like to use this for profiles, to show the flow directions.
Message 11 of 12
1wildwes
How do you add the Expression to the label?
Tags (3)
Message 12 of 12
1wildwes
in reply to: kiss
Did you ever figure this out? I'm having the same problem.
Rail Community
