Civil 3D Forum
Feature Line Elevations
2 REPLIES 2
cderrico
185 Views, 2 Replies
C3D 2008
Creating a FL starting with an Arc and using the Secondpnt option does not honor the starting elevation.
Create a FL
Pick a point on screen
Choose an elevation (35.0)
Select the Arc option
Specify a start direction (not sure why the user could not specify Secondpnt at this point in the command)
Select the Secondpnt option
Pick two points (Distance 32.61', Grade 0.00, Slope Horizontal, Elevation 35.00')
Specify Grade (-0.75)
Enter to terminate the command
Enter the Elevation Editor
Station 0+00 elevation = 0.0
Change the Elevation to 35.0 and the Grade Ahead is calculated as -0.75
Charles
2 REPLIES 2
tcorey
in reply to: cderrico
Sure enough, this works (or doesn't work) as you say. The first point goes to 0 and the second point uses the elevation you specify for the first point.
Service pack 1!
Tim Corey
Redding, CA
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
dana.probert
the transition command has a similar glitch
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
Rail Community
