Solved by BrianHailey. Go to Solution.
Solved by Jeff_M. Go to Solution.
Exactly what steps are you doing to create the featuelines?
neilyj (No connection with Autodesk other than using the products in the real world)
You are having site issues. Never put two things in the same site unless you intentionally want them to interact with each other. Your breaklines for your surface are probably featurelines and the new featurline you are creating is in the same site as your breaklines. Put them in different sites.
HERE is a little bit more information.
