Why do they do this? I am trying to quick elevation edit a featureline but my edit glyph jumps to a completly different featureline that is near.
Solved by Jeff_M. Go to Solution.
I haven't heard of that one. It might help others if you posted your current version and SP level.
Allen
Allen Jessup
CAD Manager - Designer
The command defaults to editing featurelines in the Site last used by this command. Even if you select a f/l then initiate the QuickElevationEditor, it doesn't automatically use the selected f/l's site...pretty dumb, imho. Enter S for Site, then select the f/l you want to edit, you will then be able to work as intended.
