In Civil3d (2011) I have set a grading feature line with manually set elevations for the perimeter of the parking area. Afte rI was done, I noticed I should raise the site 1 foot to eleminiate some cut. I went back to fine tune one of the curb lines and notice the elevations assigned to the feature line are on the originally set elevations, exactly 1 foot off the resulting contours. Is this a normal bahavior?
If you raised the surface using the surface edit to add 1 foot, this does not affect the objects used to build the surface. Feature lines, points, and other objects stay at their original elevation. The resulting surface will take the original elevation and add 1 foot when it generates. To keep everything in sync, the 1-foot adjustment needs to be addd to the feature lines, not as a surface adjustment.
Thak you for the reply. How wonderfully ineffective this is. Now I have feature lines 1 foot off and others on the mark.
If you select the feature lines and only the feature lines you can find the Raise/Lower command with a right click.
John Mayo
You don't have to select all of the Feature Lines. Just the ones that need to be moved. In this case the ones that were not created with the datum shift.
John Mayo
