I have a couple of shape files of museaums, historic markers and landmarks attached through FDO. The text looks good in modelspace but extreamly pixelated in the viewport. I've tries matching scales and anno scales from MS to the viewport. But it still looks the same.
Anyone know what I'm doing wrong? I'll attache an example from MS & PS
Allen
Allen Jessup
CAD Manager - Designer
Solved by AllenJessup. Go to Solution.
Allen
FDO lables don't like PS. Then add the label style you are using makes it hate PS that much more. You can try using a simple font/txt style to lable then use the convert lables to text "_MAPLABEL2ANN" to convert it to plain mtext then set that mtext to a sytle you need. Granted you would not have the text fill with outline but it will display better in PS.
Thanks for the reply Murph. The problem turned out to be ShadeMode. I had it set to Shaded because I wanted to plot a Surface, behind the map, shaded. This caused other problems. So I plotted the shaded Surface to a Raster, set the Surface to No_Display and inserted the raster to show the shaded Surface.
Now that ShadeMode is back to 2D wireframe. The labels plot from paperspace with no problem.
Allen
BTW for others. ShadeMode is the command line equivalent of Visual Styles.
Allen Jessup
Allen
Good to know, they must of fixed a few lines of code in newer versions, I know back in 2009/10 beta I turned in a ton of bugs with FDO and PS.
